Multisim and Ultiboard
Object would have more then one attribute with the tag :VALUE
I'm creating a new component in Ultiboard - a 100 pin connector.  This connector (Hirose) has 4 rows of 25 pins. Alternate rows are staggered. I'm trying to name each pin with it's appropiate name: A1, A2, A3 ....A50. Then B1, B2, B3 .....B50.
When I change the VALUE or NUMBER attribute, I get the DRC error  message:
This action cannot be completed because the resulting Object would have more then one attribute with the tag :VALUE
Please remove one of the attributes and try again.
Okay, so I've tried deleting the tag and now I can't name the pin at all.
What am I missing?
(3,118 Views)
You should be in the footprint editor to edit the pin name.  Select tools>>Database>>Database Manager, highlight the component in your database and click on the Edit icon.  In the footprint editor, double click on the pad and a SMT or THT pin Properties dialog appears, select the Attributes tab and highlight the Number row, press the change button and you should be able to change the pin name.
Tien P.
(3,078 Views)
