01-09-2017 08:11 AM
Hi all,
I'm drawing up some schematics using Multisim 14 and am looking for a way to hide the component names that are automatically placed next to said components. In these cases, the component names are typically just a string of numbers that are not important for the schematics. Is there a way to hide them without completely deleting or changing the name in the database? As seen in the attached picture, I am using other labels that are included, but if the only way to hide the component name is to hide the whole title block, then I can easily just add a separate text block.
Using the image as an example - what is there is what I currently have and I am trying get rid of the "1581," which is the component name in the database.
Any help would be greatly appreciated, thanks!
01-09-2017 09:01 AM
Hello..
your problem is solved simply. .. the right mouse button on the object-choose properties-display and further relieve the "birdies.".
01-09-2017 09:10 AM
Didn't realize it was that simple....thanks for the help!
