Multisim and Ultiboard
Default PCB templates
Does Ultiboard provide a way to redefine what the default PCB project contains?
Right now, when you open Ultiboard and select "Create new project..." it opens to the design space with nothing there.  Which is cool; you just then draw your board rectangle, add a title block, etc, etc, life goes on.
However, we are looking to keep our layout design as consistant as possible between the different engineers.  So, what I would like to do is create an empty board outline, add a title block and any other text descriptions fields that I want and then save it as the default new project template.  This way, the next time I create a new board I start with my preconfigured title block and description fields arrangement.  Is this possible?
(5,359 Views)
Update:
I have seen in the Global Options -> Paths tab the field for Templates default path.  But I'm not really sure what this is for.  The only description I can find of this field is: "This is where custom template files are located".  Custom template files for what? Part footprints? Board shapes?
(5,350 Views)
Accepted by Thomaz588
Hi there,
Multisim/Ultiboard includes the ability to create user templates, basically a Multisim file (for your schematic) and an Ultiboard file (for the PCB layout). Details can be found at:
Prototype Rapidly with Multisim and Ultiboard User Definable Templates
Hope this helps!
Fernando
Fernando D.
(5,313 Views)
