I'm trying to do buffered event counting using general purpose counters on an e-series board. It doesn't work quite as advertised. Each point in the buffer is supposed to contain the count of source events that occurred between successive pulses of the gate, according to the Nidaq function reference manual. I find, however, that every point contains the cumulative number of events, so the data are monotonically increasing. Is there a setting somewhere to change this behavior, or is there an error somewhere - either in the documentation, or in the code?
This was with NI boards 6711 and a 6035 in a G4 running OS 9.
