hello !
I am running Ubuntu (I know that Ubuntu is not officaly supported by NI but I do not have the choice of the distribution...) and I want to install the drivers of the NI-USB 6008, but I have some problems ! The installation script does not work :
error: Failed dependencies:
kernel >= 2.4.0 is needed by nikali-1.4.0-f0.i386
/bin/sh is needed by nikali-1.4.0-f0.i386
/bin/sh is needed by nipali-1.11.1-f0.i386
/bin/sh is needed by nirpci-3.3.0-f0.i386
/bin/sh is needed by niorbi-1.5.0-f0.i386
/bin/sh is needed by nidimi-1.5.0-f0.i386
/bin/sh is needed by nipxirmi-1.6.0-f0.i386
ld-linux.so.2 is needed by nipxirmi-1.6.0-f0.i386
libdl.so.2 is needed by nipxirmi-1.6.0-f0.i386
libc.so.6(GLIBC_2.0) is needed by nipxirmi-1.6.0-f0.i386
libc.so.6(GLIBC_2.1) is needed by nipxirmi-1.6.0-f0.i386
libc.so.6(GLIBC_2.1.3) is needed by nipxirmi-1.6.0-f0.i386
libc.so.6(GLIBC_2.2) is needed by nipxirmi-1.6.0-f0.i386
libdl.so.2(GLIBC_2.0) is needed by nipxirmi-1.6.0-f0.i386
libdl.so.2(GLIBC_2.1) is needed by nipxirmi-1.6.0-f0.i386
libpthread.so.0(GLIBC_2.0) is needed by nipxirmi-1.6.0-f0.i386
libpthread.so.0(GLIBC_2.1) is needed by nipxirmi-1.6.0-f0.i386
/bin/sh is needed by nicvirte-8.0-5.i386
/bin/sh is needed by labview80-rte-8.0.1-1.i386
/bin/sh is needed by nivisa-4.0.0-f0.i386
/bin/sh is needed by nivisa-devel-4.0.0-f0.i386
/bin/sh is needed by nivisa-config-4.0.0-f0.i386
/bin/sh is needed by nivisaserver-4.0.0-f0.i386
/bin/sh is needed by nispyi-2.4.0-f0.i386
Running NI-KAL Post Installation Script ...
******************************** ERROR ****************************************
* Kernel source in /lib/modules/2.6.20-16-generic/build does not appear to be
* for the 2.6.20-16-generic kernel.
* Ensure that kernel source for the 2.6.20-16-generic kernel is installed
* and configured. Refer to the README file for the product you are *
* installing for information about configuring your kernel source. *
./uninstall.sh: line 13: Makefile.in: No such file or directory
But all is ok... and should work !
So, I convert the .rpm packages to .deb packages then I install the .deb and when I run 'lsdaq' :
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
/usr/local/bin/lsdaq: line 7: 14722 Aborted /etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices
the niSystemReport show :
/usr/local/bin/niSystemReport version 1.4.0f0
/bin/uname -a:
Linux jay 2.6.20-16-generic #2 SMP Thu Jun 7 20:19:32 UTC 2007 i686 GNU/Linux
/etc/lsb-release:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=7.04
DISTRIB_CODENAME=feisty
DISTRIB_DESCRIPTION="Ubuntu 7.04"
/usr/local/natinst/nikal/src make:
Makefile:11: Makefile.in: No such file or directory
make: *** No rule to make target `Makefile.in'. Stop.
/home/gardet/CD
/usr/bin/tail /var/log/messages:
Jun 18 10:58:42 jay niusb9161dlfw: [libnipalu.so.1.11] Warning: source/package/posix/ulibEntry.cpp:191 - initialize: unable to load NI-PAL. status=-50204
Jun 18 10:58:53 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/lib/linux/linLoadKern.cpp:168 - libKernelDriverLoad: Failed to open nipalk, errno: 2
Jun 18 10:58:53 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50204
Jun 18 10:58:53 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/package/posix/ulibEntry.cpp:191 - initialize: unable to load NI-PAL. status=-50204
Jun 18 10:58:56 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/lib/linux/linLoadKern.cpp:168 - libKernelDriverLoad: Failed to open nipalk, errno: 2
Jun 18 10:58:56 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50204
Jun 18 10:58:56 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/package/posix/ulibEntry.cpp:191 - initialize: unable to load NI-PAL. status=-50204
Jun 18 11:04:28 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/lib/linux/linLoadKern.cpp:168 - libKernelDriverLoad: Failed to open nipalk, errno: 2
Jun 18 11:04:28 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50204
Jun 18 11:04:28 jay daqmxbase_listdevices: [libnipalu.so.1.11] Warning: source/package/posix/ulibEntry.cpp:191 - initialize: unable to load NI-PAL. status=-50204
/usr/local/natinst/nikal/src/Makefile.in: File not found!!!
/usr/local/bin/niSystemReport: line 95: /usr/local/natinst/nikal/src/Makefile.in: No such file or directory
If someone know what I have to do...
Guillaume.
