Multifunction DAQ
Write measurement data to text file every 10 seconds for duration of 2 seconds, creating a new file each time.
Greetings,
I am working on a data acquisition application that runs continuously and needs to log data at 10 second intervals for a duration of 2 seconds.
On every logging interval I have to create a new file that contains a log number in the filename (Test_1.txt, Test_2.txt, ...);
and add current time and date to the file header.
My question is how can I do this with what I have so far?
The attached vi is a concept of what I am trying to accomplish. The original application also has the DAQmx read functions in the surrounding while loop,
and some data manipulation. Outside the main loop I create and start DAQmx tasks.
Thank you for your help.
Best regards
Matej
/* A smart device is only as smart (stupid) as its programmer. */
(3,696 Views)
Accepted by topic author DsX
Figured this one out myself. 😉
Here is the solution if anyone needs something similar.
Best regards
Matej
(3,656 Views)
