06-09-2011 04:14 PM
Solved! Go to Solution.
06-09-2011 05:45 PM
06-10-2011 12:16 PM
Hi Don,
Have you already installed VISA and NI-KAL before attempting to install DAQmx? Our read me lists all the versions we have tested the install on and can verify it's functionality. Since Advanced Server does not exist on the list means that either it is not supported or we just haven't tested it yet. In theory it should have no problems installing because it is still RHEL, just renamed. I've attached the Knowledge Base below that explains a little more in detail what OS's are supported as well as the need for NI-KAL.
What Linux Distributions Do National Instruments Drivers and Software Support?
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument
Kyle S
06-10-2011 02:16 PM
06-13-2011 05:43 PM
In case anyone else has this problem, I was able to resolve it by (1) adding -m32 to the FLAGS in the Makefile, and (2) by following these instructions:
"During the build of the examples, the linker may report that liblvrtdark.so has
unresolved symbols in the Standard C++ Library. This is a known issue as of
NI-DAQmx Base 3.4 on Red Hat Enterprise Linux WS 4. To properly link and run
the examples, make the following modifications to the Makefile.
Add /usr/local/lib/LabVIEW-2010/patchlib/libstdc++.so.6 to nilibs.
Add -Wl,-rpath,'/usr/local/lib/LabVIEW-2010/patchlib' to the flags." from the README:
http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmxbase/3.4/Linux/README.txt
Don
