09-15-2014 02:10 PM
Hi!
There is a PCI-6023e National Instruments in my system but the analog inputs are in high positive or negative level. I verified the control panel and Max instalation It was ok.
I installed a battery of 1,5Vdc on the analog inputs to verify voltage measurement but the measurement remained saturated with 10 Vdc in all channels.
Rafael Leite
09-15-2014 02:50 PM
09-15-2014 03:09 PM
My setup is CSR. I connected the battery pins AIGND 67 (-) and 68-CH0 (+) and also in other channels.
09-15-2014 04:03 PM
09-16-2014 08:00 AM
Hi Rafael,
The best connection approach using a battery is RSE or just single-ended. You can find details here:
http://www.ni.com/white-paper/3344/en/
Test the board using MAX with a known source of signal, if using DAQmx driver execute self-test and self-calibrate.
Make sure that any software change was made in this machine, and if was tell us what changed.
If you have any doubt feel free to contact us,
