Problem with my PCI-6023e
Hi!
There is a PCI-6023e National Instruments in my system but the analog inputs are in high positive or negative level. I verified the control panel and Max instalation It was ok.
I installed a battery of 1,5Vdc on the analog inputs to verify voltage measurement but the measurement remained saturated with 10 Vdc in all channels.
Rafael Leite
(3,946 Views)
What is your configuration (differential/rse) and what pins do you connect the battery to?
(3,939 Views)
My setup is CSR. I connected the battery pins AIGND 67 (-) and 68-CH0 (+) and also in other channels.
(3,936 Views)
What is CSR? The physical connection is referenced single ended. Do you actually have a gnd that you connect to pin 67?
(3,930 Views)
Hi Rafael,
The best connection approach using a battery is RSE or just single-ended. You can find details here:
http://www.ni.com/white-paper/3344/en/
Test the board using MAX with a known source of signal, if using DAQmx driver execute self-test and self-calibrate.
Make sure that any software change was made in this machine, and if was tell us what changed.
If you have any doubt feel free to contact us,
Barbara Pracek
Engenharia de Aplicações
National Instruments Brasil
(3,916 Views)
