NI USB 6009: NIDAQmxBase examples hang in Ubuntu 10.04.1
Hello !
I installed NIDAQmxBase in Ubuntu 10.04.1 Server following the various instructions in this forum. After a lot of trial and error I managed to get the NI-USB 6009 recognized in lsdaq.
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
NI USB-6009: "Dev1"    (USB0::0x3923::0x717B::01586A5A::RAW)
However the examples hang.
These are my kernel modules:
arc4                    1153  2
bitblit                 4707  1 fbcon
cfg80211              126528  2 rt2x00lib,mac80211
crc_ccitt               1339  1 rt2800usb
fbcon                  35102  71
font                    7557  1 fbcon
i2c_isch                3375  0
led_class               2864  2 rt2x00lib,sdhci
lp                      7028  0
mac80211              205402  2 rt2x00usb,rt2x00lib
mii                     4381  1 r8169
Module                  Size  Used by
nidimk                322759  2 nipxirmk
nikal                  57594  1 nipalk
niorbk                 95647  2 nipxirmk,nidimk
nipalk               1220783  6 NiViPciK,nipxirmk,nidimk,niorbk
nipxirmk              115018  1
NiViPciK               79087  0
output                  1871  1 video
parport                32635  1 lp
pata_sch                1963  0
psmouse                63245  0
r8169                  34364  0
rt2800usb              31531  0
rt2870sta             461971  0
rt2x00lib              27541  2 rt2800usb,rt2x00usb
rt2x00usb               9703  1 rt2800usb
sdhci                  15654  1 sdhci_pci
sdhci_pci               5502  0
serio_raw               3978  0
snd                    54180  6 snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer
snd_hda_codec          74201  2 snd_hda_codec_idt,snd_hda_intel
snd_hda_codec_idt      51978  0
snd_hda_intel          22101  0
snd_hwdep               5412  1 snd_hda_codec
snd_page_alloc          7172  2 snd_hda_intel,snd_pcm
snd_pcm                70918  2 snd_hda_intel,snd_hda_codec
snd_timer              19098  1 snd_pcm
softcursor              1189  1 bitblit
soundcore               6620  1 snd
tileblit                2031  1 fbcon
usb_storage            39585  2
vga16fb                11385  1
vgastate                8961  1 vga16fb
video                  17375  0
These are the running processes (for clarity I included only the processes with names starting with ni):
1222 pts/0    00:00:00 nipalps
 1234 ?        00:00:00 niLxiDiscovery
 1242 ?        00:00:00 nimdnsResponder
 1248 ?        00:00:00 nipalsm
 These are the installed ni packages:
ii  nidaqmxbase-board-support       3.4.0-1                         NI-DAQmx Base Hardware Support
ii  nidaqmxbase-cinterface          3.4.0-1                         NI-DAQmx Base API (C version)
ii  nidaqmxbase-common              3.4.0-1                         NI-DAQmx Base Common Configuration Utilities
ii  nidaqmxbase-labview2009-vis     3.4.0-1                         NI-DAQmx Base API (LabVIEW 2009 version)
ii  nidaqmxbase-labview2010-vis     3.4.0-1                         NI-DAQmx Base API (LabVIEW 2010 version)
ii  nidaqmxbase-labview85-vis       3.4.0-1                         NI-DAQmx Base API (LabVIEW 8.5 version)
ii  nidaqmxbase-labview86-vis       3.4.0-1                         NI-DAQmx Base API (LabVIEW 8.6 version)
ii  nidaqmxbase-usb-support         3.4.0-1                         NI-DAQmx Base USB Device Support
ii  nidimi                          1.10.0-f0                       NI-DIM
ii  nimdnsresponder                 1.1.0-f3                        National Instruments mDNS Responder Service
ii  niorbi                          1.9.3-f0                        NI-ORB
ii  nipxirmi                        1.6.0-f0                        NI-PXI Platform Services
ii  nirpci                          4.2.0-f0                        NI-RPC user library
un  nis                             <keine>                         (keine Beschreibung vorhanden)
ii  nivisa                          5.0.0-f0                        NI-VISA Runtime Engine -- Abtraction layer for access to NI-488, PCI/PXI, USB,
ii  nivisak                         5.0.0-f0                        NI-VISA Runtime Engine Kernel Support
These are the dependencies of the example program:
linux-gate.so.1 =>  (0xb78df000)
	libnidaqmxbase.so.3 => /usr/local/lib/libnidaqmxbase.so.3 (0xb78d2000)
	libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb78b3000)
	libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7758000)
	libnidaqmxbaselv.so => /usr/local/lib/libnidaqmxbaselv.so (0xb774e000)
	/lib/ld-linux.so.2 (0xb78e0000)
	liblvrtdark.so.10.0 => /usr/local/lib/liblvrtdark.so.10.0 (0xb6529000)
	libstdc++.so.6 => /usr/local/lib/LabVIEW-2010/patchlib/libstdc++.so.6 (0xb6447000)
	libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb6421000)
	libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb641d000)
	libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0xb6404000)
I would greatly appreciate your help to find out what makes the examples hang.
Due to post size limitations I will post my gbd debug session in the next post.
Martin Jukel
(5,337 Views)
It turned out the I was just too impatient. However, it seems strange to me why it takes so long to start
time ./acquire1Scan
Acquired reading: 0,003858
real	1m9.577s
user	1m8.840s
sys	0m0.388s
As you can see the process takes 100% CPU time (confirmed by monitoring with top also).
I modified the acquireNScans sample so that 100x1000 samples are taken. This is the result:
time ./acquireNScans
Acquired 1000 samples
data[0] = -0,005064
data[1] = -0,001240
data[2] = -0,005064
data[3] = -0,002515
data[4] = -0,001240
data[5] = -0,002515
data[6] = 0,000034
data[7] = 0,003858
data[8] = 0,002583
data[9] = 0,002583
real	1m19.248s
user	1m9.744s
sys	0m0.616s
Therefore it seems to me that this is a startup problem, because with acquireNScans the elapsed real time is 9,671s  longer whereas the consumed user time is only 0,904s longer.
Help to find the cause for this would still be appreciated.
Martin Jukel
(5,334 Views)
Accepted by topic author Martin Jukel
Yes, and there is a workaround. Please see my post in another thread:
libnipalu.so failed to initialize
http://forums.ni.com/t5/Multifunction-DAQ/libnipalu-so-failed-to-initialize/m-p/1282246#M60196
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(5,323 Views)
It works now as expected. Many thanks for your help.
Martin
(5,272 Views)
I was happy to see that someone managed to install NIDAQmxBase in Ubuntu 10.04.1, which is exactely what I want to do. When I read further though, I realized that you'd already solved that problem...
I've been lookin around in the forum to find solutions, but I'm not sure where to start. I read somewhere that the drivers need to be compiled for the used kernal. I that necessary?
Could you give some hints on what forum entries to look at?
Thanks.
(4,950 Views)
Hi Martin,
I am trying to install the NiDAQmxBase in Ubuntu 11 because I need to work with a NI-USB 6009. Could you please give me any clues? I've looking in the forum for some time without any success at all.
Thanks in advance
Acebo
(4,526 Views)
