NI 9174 power input wiring
Hello All,
I am using NI 9174 chassis and NI PS15 power supply which provide 24Vdc. connection are pin V wired to +24Vdc, pin C wired to -24Vdc.
But Seems like this connects pin C to ground too. Is there internal connection in the chassis that makes pin C connects to ground (enclosure)?
Now I have all my COM are connect to Gound which I don't have in my drawing.
Can any one explain this?
Thank you very much
Message 1 of 12
(5,121 Views)
Ya-hoo,
Have you checked the output of the power supply with a DMM? It might be worth making sure the voltage is what you think it is. I would also recommend looking through the manual for the NI 9174.
-aprillest
Message 2 of 12
(5,096 Views)
Yes, output of the power supply is 24Vdc.
Message 3 of 12
(5,090 Views)
There is no -24V connection so what you are saying doors not make much sense.
Message 4 of 12
(5,081 Views)
I mean negative of 24Vdc power supply.
Message 5 of 12
(5,072 Views)
According to the user manual for the NI cDAQ-9174, (link) it appears that the safe voltage input range is 9-30V. A range of -24V to 24V would be a 48V range, which is outside the limits for this device. Can you use a lower power range (i.e. -15V to 15V) for your application?
Message 6 of 12
(5,028 Views)
Hi All,
I am sorry for the confusion. Here is the clarification of my wiring.
I am using NI PS15 as power supply and connection is as in the picture.
Message 7 of 12
(5,019 Views)
The connections look correct. What exactly is wrong? Doesn't the 9174 power up?
Message 8 of 12
(5,008 Views)
9174 is powered up and system seems working fine.
One thing I'd like to know is why the COM is connected to system GROUND once V and C of 9174 are connected.
Message 9 of 12
(5,002 Views)
The C of the 9174 stands for common and that is ground.
Message 10 of 12
(4,993 Views)
