May I Know wiring configuration bet. DAQ-ai-16e-4 and SCB-68 I/O block
We have the 'DAQCard-AI-16E-4' with PSHR 68 68 cable and a scb-68 connector block to connect the signals to this daq card. and also NI-DAQ software.
May I know the wiring configuration between DAQCard-AI-16E and scb-68.
Kindly provide me detail wiring configuration between that two. and also application note if any for perticular this card with Laptop connection.
Thanking You,
Rajesh Patel,
Research Scholar
IIT Roorkee (INDIA)
(2,299 Views)
Please find attached a file in the bmp format that gives the pin-out diagram for the PSHR68-68M cable (PSHR68-68 is a shielded cable kit that contains a PSHR68-68M cable).
You can also get the same pin-out diagram from National Instruments website if you go to the following link and type '2XIH98R9' in the search box.
http://search.ni.com/?layout=KB
Here's the webpage for PSHR68-68 and you can find more information about it here in the Product Data Sheet.
http://sine.ni.com/apps/we/nioc.vp?cid=11808〈=US
This DAQCard has 16 AI channels, 8 DIO lines and 2 counters. These can be located in the diagram for the PCMCIA end (DAQCard-AI-16E-4) as well as the SCB-68 connector end, alongwith GND lines.
I hope this answe
rs your question. Please let us know if you have further questions. Thank you for choosing National Instruments !
Swapnil P.
National Instruments Engineer
(2,299 Views)
