 Aloika
			Aloika
			01-28-2010 05:03 AM
The absence of official support of interaction between NiDAQmx driver and RAD Borland (Embarcadero) Delphi is the actual problem. Many application developers want to support existing projects and develop new ones using the familiar programming environment. However, we suppose that new-created Delphi projects must support various DAQ cards and operation systems of the Windows family including 64-bit versions. Existing Delphi applications written with the legacy Traditional NiDAQ driver must be easy converted to work with a new NiDAQmx driver.
There are two methods to solve this problem partially.
1. Using TDAQ7.4 for Windows Vista. This method allows to use existing Delphi applications for Windows Vista x86 and Windows 7 x86. But this driver doesn’t support a lot of modern DAQ cards and doesn’t work in 64-bit operations systems. Using TDAQ7.4 driver for Windows Vista can be only a temporary solution.
2. Using wrappers for the nidaqmx.dll library. The limitations of this method are dependence between NiDAQmx version and wrapper version (changing of driver’s version involves changing wrapper); nidaqmx.dll functions are not well documented; there are strange bugs and memory leaks; 64-bit operation systems are not supported yet; working of this method is not guaranteed at all.
I want to propose a new solution of interaction of the NiDAQmx driver and Borland Delphi. The essence of the approach is described below.
1. Create .NET-assembly using Microsoft Visual C# 2008 Express Edition (for example), in which describe one or several objects contained necessary DAQ-functionality.
2. Select names of methods, properties and events corresponding with name of old driver’s members. This creates an opportunity to simplify the process of remaking existing Delphi applications.
3. Register the assembly for Com Interop.
4. Import the .NET-assembly in Borland Delphi. Now we have an object the same as, for example, ActiveX object with an encapsulated necessary DAQ-functionality.
Advantages of described approach are:
Using described method I have already created .NET assembly with realization several functions for one-shot digital reading and writing, continuous analog reading, one-shot analog writing (I need only this functionality for my own applications).
If this topic is interesting for you please write me karpesh@mail.ru or soft@electrolab.ru (English and Russian available).
