04-23-2012 05:07 PM - edited 04-23-2012 05:10 PM
Dear Mr../ Mrs..
I have DC-motor with Encoder (4000 inc. pr. turn) and EPOS2 motor controller from Maxon Motor. I want to use the EPOS2 Interpolated Position Mode (IPT Mode), but can't find any examples anywhere. I have read read much of the documentation for the EPOS2 and also browsed the examples (there isn't any specific for the IPT mode). Furthermore I can get the Position Profile and Velocity Profile modes works - so there is hope ;-) The labview program is executed on my PC, communicates with the EPOS2 on a CANopen network, through a USB-CAN converter from IXXAT.
I have attached my program - this is only a test program where I buffer 2-4 values manually written values and starts the trajectory. I can initialise and send values to the buffer, but when I start the IPT trajectory the axis turns into Fault state and the motor does not move. If I clear Fault state afterwards it turns over to disabled state. I gues I have to specify some more parameters? But I don't know which ones. Furthermore I might think, that I should place the functions in the move case structure in a while loop or change the mechanical action in order to execute the whole trajectory?
Thanks in advance
Best Regards
Søren Mark
07-05-2012 12:49 PM
Have you found any examples yet?
I think your errors are a result of your target position being initially too far away from your starting-actual position. If there is too much of a discrepancy, then you'll get an error (common with other operating modes also).
I'm currently working on the same problem, maybe we can help each other out.
~Aaron
03-24-2013 04:50 PM
Were you able to find a working solution - I am about to tackle this same problem with a EPOS2 and IPT mode. Any guidance will be very much appreciated!
David
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
