Measurement Studio for VC++
Why are updates to CNiKnob and CNiSlide so slow?
In testing the effects on CPU usage (on my Win2k PC) I find that setting the value of a CNiKnob or CNiSlide is considerably more expensive than adding points to a CNiGraph object. (I am using SetValue() for the knob or slider and ChartXY() for the graph.) This is true even when the knob or slider is not on a visible screen, so it is not just a drawing issue.
This seems surprising to me, so I am wondering if I am doing something wrong. Are there any settings that have a big impact on the speed or efficiency with which sliders or knobs are updated? (Note that I need multithreaded access to these objects, so I am using the default constructor argument which specifies the MultipleThreadsWithCaching ThreadAccess option.)
Thanks in advance.
Wayne
(3,243 Views)
That's interesting ... could you please post a small test project that demonstrates this behavior? Thanks.
- Elton
(3,243 Views)
Elton,
I do not really have time right now to strip my app down to a test project to demonstrate the effect.
I can tell you that, when I run my app on my development PC (Win2k, 730 MHz Pentium), I get a baseline CPU usage of < 10% for about 80% of the time with occasional spikes up to ~50% usage. Adding a single slider (updating at 50 Hz) bumps the CPU usage up to about 50% for about 40% of the time. If I get up to 6 sliders, CPU usage pegs out at 100% all the time. Knobs give similar figures. In contrast, if I update a chart with 4 plots and 4 axes and a 5000 sample buffer size at a 50 Hz rate, CPU usage only goes to about 10-20% for about 50% of the time with peaks up to about 40%.
I find it surprising that a single slider or knob seems to pla
ce higher demands on my system than a chart with multiple plots. Is this what you would expect from your own testing at NI?
Wayne
(3,243 Views)
I wasn't necessarily asking for you to strip down your app to demonstrate the problem - I was thinking that you could create a new project and just add enough to it to demonstrate the problem. I tried creating a test project that had one graph, 7 knobs, and 7 sliders, and I had it plotting data every 100ms and the max I saw my CPU usage go up to was 30%.
- Elton
(3,243 Views)
