VS 2005 crashes when using forums
Have VS 2005 pro with MS 8.0.1 pro. Have had three crashes of VS when I select these forums from the VS IDE. Luckily VS automatically restored files next time I opened it, but rather risky.
PC is fairly new with reasonably clean install of VS and MS. I have not have any earlier versions of VS or MS on it.
To prevent this I am using IE 6.0.2900 to view forums, not VS.
Anyone else have similar experience? Any suggestions of how to prevent?
(3,020 Views)
Hi Steve,
I haven't noticed any errors when I access the NI forums from the Visual Studio browser; however, I don't have a large sample size to speak from.
Is this happening every time you access the forums or is it completely random? Furthermore, is it every time you access a specific forum or is this also random?
I would assume that this is not a Measurement Studio problem; rather it is a Visual Studio error. Perhaps if there is an error code or message describing the crash, we can investigate this more thoroughly.
Matt Mueller
NI
(2,997 Views)
Matt,
Unfortunately it does not happen every time I access forums. The error message is the usual 'we are sorry but VS must terminate with an unknown error', yada, yada, yada. I once tried sending the error report but it was taking so long that I gave up.
One possibility is that sometimes I have the project I'm working on open  as well as the forums. Then I'm looking at example solutions which starts another VS session. Of course I bounce back and forth between them.
I'll try to get more info on the crash and send it along.
Thank you,
Steve
(2,992 Views)
