EditRangeDateTimeFormatMode used for... ?
In my IntensityGraph, the YAxis has two properties: EditRangeNumericFormatMode, and EditRangeDateTimeFormatMode. Presumably this means I should be able to set my axis to display either time format or numeric format, and use these properties to control the details of how those are displayed. Problem is, I can't figure out how to setup the axis to display time. All the plot and axes properties seem to support numeric value but not time value. How do I get the IntensityGraph to display an axis as time value?  Thanks.
(5,950 Views)
Hi there,
To display time on the scale/axes you need to set the LabelFormat to appropriate value.
The following code snippet should be clear to make you understand how to do it.
intensityXAxis1.MajorDivisions.LabelFormat = new FormatString(FormatStringMode.DateTime, "G");
Vijet Patankar
(5,945 Views)
OK, thanks. I guess the reason I missed this is that the VS properties editor does not give you the option of configuring date/time format from the GUI. So, configuring it via line of C# code is the only option. It would be good to mention this in the documentation for EditRangeDateTimeFormatMode.
(5,940 Views)
Hi there,
You can set the LabelFormat property in different ways at design time.
Method1)
Method2)
Vijet Patankar
(5,937 Views)
Thanks. But my point is, I did not see Date/Time type of option in the list.
(5,934 Views)
Never mind - I did not notice the 'Category' header at the top. Thanks!
(5,933 Views)
