Machine Vision
pattern matching program
I am creating a program that does pattern matching on a video. I want the program to be able to open a template to be used for the pattern matching template and to allow the user to select a template from an image in Labview and then use this template as the pattern matching template. I have code that does all of this. The part that allows a user to select a template in Labview is a sample program that comes with Labview. I just do not know how to incorporate it. Thanks.
Message 1 of 57
(5,212 Views)
Hi frog7,
What vision software and version are you using for this? It would be helpful to the community if you can post some screenshots of the two pieces of code you are trying to integrate. Thanks!
Message 2 of 57
(5,191 Views)
Hi frog7.
Can you explain clearly what do you want.. If you want to learn a template when your program in run mode you can use Learn template function in Vision Development module or copy whatever section you want from the example program and embed in your application.
Silver_Shaper | CLD
Message 3 of 57
(5,189 Views)
I have attached my program. I am attempting to have the template image from the case structure on frame 0 be carried to fram 1 and used as the template image for the pattern matching. Thanks.
Message 4 of 57
(5,184 Views)
Also, I am using Labview 2010.
Message 5 of 57
(5,184 Views)
Hi frog,
Did you got any improvement on your work.. If not, will help you to sort out.
Silver_Shaper | CLD
Message 6 of 57
(5,168 Views)
Nope. I am still stuck. Thanks!
Message 7 of 57
(5,164 Views)
Hi frog,
Here in attached vi, Ckeck it out your problem solved or not. If not, post the video file also. will help you..
Not to mention: Your vi is so big. You have to really optimize your vi.
Silver_Shaper | CLD
Message 8 of 57
(5,161 Views)
This is only my third month of using Labview. Don't know how to do that yet.
Message 9 of 57
(5,153 Views)
Hi frog,
Doing these much things in 3 Months is really good. We are really happy to help and improve you
You may find a quote on my signature..
Silver_Shaper | CLD
Message 10 of 57
(5,144 Views)
