‎10-22-2010 10:27 PM
i am using labview 8.6 and vision assistant 2009 to process the 640*480 RGB image caputured by a logitech qickcame. the problem is after the image gone through the vision assistant express VI the out put is a 640*480 all black image! however inspected from the inside of the vision assistant every process will be all right. so now i just cant get the output image! How this can be solved?
‎10-23-2010 01:15 AM
At the first check that Binary Palette was selected for right Vision Display (Right Mouse Click->Palette->Binary)! Binary image appear black with grayscale palette.
Second - (if you ensure that your images and script are OK) - you can try to debug Vision Assistant Express VI.
Save copy of your VI, then right mouse click on Express VI->Open Fron Panel, then OK. Express VI will be converted into normal VI, go inside and debug it.
Andrey.
‎10-23-2010 03:01 AM
Thank you for your reply! I can only exam the settings as early as monday. howevery i have tried your second method and i found the image all black out after the color threshold VI. any way i will check the setting on monday. Thank you very much!
‎10-24-2010 07:46 PM
Thank you Andrey! i tried your first solution and it works! problem solved. Thank you!
