Machine Vision
Pattern matching
I used the NI Vision Assistant  to consruct  a  ROI based on Pattern Matching,and the ROI is a rotated rectangle,which like this:PM.PNG
Then I slected Tools to create Labview VI,but I do not know how  the ROI Descriptor Controls to describe a rotated rectangle,especially the detailed definition of coordinates.
Could you help me?  Thanks you very much。
(4,324 Views)
Accepted by topic author 862447229@qq.com
If you hover over the ROI controls you will see blue squares which lets you to expand the visible controls. When you left click those squares and expand it, hidden components of ROI descriptor will be visible. Attached is the image which shows how ROI Descriptor for rectangle is defined. You can find these kind of information right in the Labview Help.
So, that 311739 means 311,739 degrees and it is only the angle component of rotated rectangle. The other components are x,y coordinates of top left point and bottom right point.
(4,301 Views)
Thank you for your help.And now I know how to do next,Thanks again.
(4,287 Views)
Hi Sir,
For my case, how can i define the ROI for the coin only ?
Just hover over the coin, then get the rectangle, but how to get the axis, and where should I input the axis and degree ?
Thanks.
Learning from other people
(1,011 Views)
Also could we do this match for color pic ? Thanks
(971 Views)
Hello, Anyone experienced this before ? Thanks.
(928 Views)
Hi Sir,
For the coordinates, the area need to be bigger than the template or not ?
Thanks.
(875 Views)
