06-12-2007 02:52 AM
06-13-2007
07:59 AM
- last edited on
09-25-2025
03:43 PM
by
Content Cleaner
Hi Andrej,
There are 4 Digital lines on the 1427. If you look at the user manual in Fig. 3-2, 3-3, and table 3-1 you can see what each pin is used for. In LabVIEW there is a function called IMAQ Generate Pulse3.vi using this vi you can output a digital signal. There is an example in LabVIEW that uses this vi called LL Pulse Generation.vi. I would look at that example to get started. I hope this helps.
Have a great day,
GG
