06-12-2007 04:22 PM
06-14-2007 11:23 AM
01-21-2009 03:46 PM - edited 01-21-2009 03:47 PM
Hi Justin,
Could please explain more details about how to " Add the remote system as a target to LabVIEW " as I have same problem.
Many thanks,
Wei
01-22-2009 04:15 PM
Hi Wei,
Justin was most likely describing the following procedure when he said “Add the remote system as a target to LabVIEW”
1)    In Project Explorer, right-click on the project
2)    Select New >> Targets and Devices
This will populate a list of RealTime targets that you can choose from.
Let me know if this helps!  Have a great day.
Kristen H.
01-22-2009 06:14 PM
01-23-2009 04:08 PM
Hi Way!
I think you may have forgotten to attach your screen shots. Also, could you describe (or attach a screen shot of) the message that indicated something it wrong? Thanks!
Kristen H.
01-26-2009 03:04 PM
Sorry, Let try again. I have put some notes as well.
Wei
01-26-2009 05:52 PM
01-26-2009 06:00 PM
01-27-2009 12:01 PM
Hi WeiL and grekop,
Wei - Thank you for the great screen shots and notes- you were very thorough!
Check to make sure that the VI you are running is under the remote system in the Project Explorer. You can drag it to the correct location if it is not. If the VI is under My Computer in the Project Explorer, LabVIEW will look for a camera on your local system.
If this does not work, install NI Vision Acquisition Software 8.5.1.  NI Vision Acquisition Software 8.6 does not explicitly state that it supports the 1722 smart camera, but version 8.5.1 does.
Let me know if either of these work for you!
Kristen H.
