Machine Vision
Create imageControl property subvi
How to create a subvi for this? I pressed "Creat SubVI" in "Edit" but nothing happened.
Message 1 of 11
(3,366 Views)
You have to select the region of block diagram which you want to convert to Sub VI and then press Create SubVI in Edit Menu.
For more on how to create SubVI: http://www.ni.com/white-paper/7593/en/
uday
Message 2 of 11
(3,340 Views)
I clicked the property node Zoom X and clicked Create SubVI, nothing happened.
Message 3 of 11
(3,324 Views)
Can u give me an example of a subvi using an imagecontrol as input and output its zoomX?
Message 4 of 11
(3,323 Views)
send your code I make it sub vi for you friend
Message 5 of 11
(3,321 Views)
Message 6 of 11
(3,318 Views)
could you send your vi in lower version?
Message 7 of 11
(3,316 Views)
Message 8 of 11
(3,315 Views)
Accepted by tomsze
hope it could help you to solve your problem
Message 9 of 11
(3,312 Views)
this method.pnguse this sub vi with this method
Message 10 of 11
(3,310 Views)
