NI Home
Cart Cart | Help
You are here:
Reply
Member
eberg
Accepted Solution
Can I have a global calibration, for different image sizes, in VBAI
I run a VBAI algorithm on stored images from several line-scan cameras.  We use a simple, square, calibration (.42mm/pixel) for every image, they are always 1024 pixels wide, but image length may vary.  Currently, I have to use more then 10 Calibration Wizard instances to acomodate the variations in length, but it strikes me that the resulting internal calibration is the same for every instance.  So is there a way that I can set up a single calibration an use if for any image length?
Active Participant
ChristopheC
Re: Can I have a global calibration, for different image sizes, in VBAI
That's a feature we added in the latest version of Vision Builder AI (2012), which will be available very soon.
Would it be a possibility for you to use the Run LabVIEW step to calibrate your image? If so, you can call a LabVIEW VI that sets the calibration using IMAQ Set Simple Calibration2, after the acquisition steps. Once the image is calibrated, all subsequent steps should return calibrated results, even if you're not using the VBAI built in calibration.
Christophe
Member
eberg
Christophe,
Thanks.  That covers me both in the long and short term
Eric
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
