03-16-2017 06:04 AM
I use NI Vision Assistant's Find Straight Edge Setup function, this is a "Auto Setup" can auto calculate the Edge and then display find edge's parameter, such as
Minimum Edge Strength
Kernel Size
Projection Width
Gap
See the attachment picture
now I use same parameter to Find Straight Edge, some picture's grayscale is different, so I often can't Find Straight Edge by same parameter,and then I want to do some process like NI Vision Assistant's "Auto setup" in ordhe edge, It's best to use labview code,
someone can help me!
very thanks!!!
03-19-2017 08:23 PM
NI vision assistant could generate labview code according to you set up, if I remembered right.
would you please try this way?
03-20-2017 12:14 AM
