 patil1983
			patil1983
			09-29-2015 06:59 AM
HI
I am trying to comport auto detect,
i am uisng status = viFindRsrc (defaultRM, "ASRL[0-9]*::?*INSTR", &find_list, &retCnt, instrDesc); funtion to detect port , but its working upto port 9 after 9 it not detecting correct one . please give an idea how tp slove this issue. ( comport may be 1 to 255).
thanks
Solved! Go to Solution.
 nyc_(is_out_of_
			nyc_(is_out_of_09-29-2015 07:56 AM
@patil1983 wrote:
HI
thanks
That's because you are telling it to look for com ports 0-9.
 Wolfgang
			Wolfgang
			09-29-2015 08:12 AM
nyc, doesn't the * after the [0-9] mean zero or more occurrences of the preceding character or expression?
'or more' should include ports 10, 100, ..., no?
 nyc_(is_out_of_
			nyc_(is_out_of_09-29-2015 08:19 AM
I am no regular expression expert.
the [0-9] means one digit 0 ... 9
the * means 0 or more times
 Wolfgang
			Wolfgang
			09-29-2015 08:22 AM
so this means that 'That's because you are telling it to look for com ports 0-9.' is not correct... it should also find ports with numbers larger than 9...
 nyc_(is_out_of_
			nyc_(is_out_of_
		09-29-2015
		08:36 AM
 - last edited on
		06-09-2025
		09:14 AM
 by
		 Content Cleaner
			Content Cleaner
I am not sure where the OP got his example code from.
The LabVIEW example VI at https://forums.ni.com/t5/Example-Code/Obtaining-a-List-of-Only-the-COM-Ports-as-VISA-Resource-Names/... uses the expression ASRL?*::INSTR which is very similar to what I used to find my USB scope.
It doesn't look like it is a real regular expression.
According to the LabVIEW Help,
? matches any one character
* matches any 0 or more occurences of the preceding character or expression.
[list] matches any one character from the enclosed list. You can use a hyphen to match a range of characters
 nyc_(is_out_of_
			nyc_(is_out_of_09-29-2015 08:37 AM - edited 09-29-2015 08:39 AM
No, if it was a regular expression it will NOT find numbers greather than 9.
I suggest that you look up what [0-9] actually means for a true regular expression.
Brackets means a list and with the hyphen, you are looking 0 or 1 or 2 or 3 or 4 or 5 or 6 or 7 or 8 or 9.
That is it.
 Wolfgang
			Wolfgang
			09-29-2015 08:57 AM
if you say so...
all I can tell is that viFindRsrc ( resource_manager_handle, "ASRL[0-9]*::?*INSTR", &find_handle, &return_count, instrument_descriptor ); does find all my serial ports, and I do have more than 30
 RobertoBozzolo
			RobertoBozzolo
			09-29-2015 08:57 AM
Findind the correct search expression can be a challenge!
If I search with "ASRL[0-20]*::?*INSTR" function fails to recognize port 4, while "ASRL[0-24]*::?*INSTR" finds it; "ASRL[0-256]*::?*INSTR" fails too
However, the expression in brackets is not a simple list, since even "ASRL[0-4]*::?*INSTR" finds port 10 (for what is worth, "ASRL[1-4]*::?*INSTR" doesn't locate port 10).
I am not an expert on Visa and even less on regular expressions, but it seems to me that "ASRL?*INSTR" as mentioned before should be the best search string. Next he will need to discriminate the parallel port if it exists in the system, which is counted too by the call.
 Wolfgang
			Wolfgang
			09-29-2015 09:01 AM - edited 09-29-2015 09:04 AM
Roberto, I would assume that [0-2]* means 0,1,2,00,01,02, ... and accordingly it will not find port 4. The same is true for [0-256]*.
And, for the same reason, ASRL[0-4]* finds port 10 because 0-4 includes 0 and 1, and * means repetitive.
