06-13-2016 04:06 AM
Well, That's OK, Thank you!
06-14-2016 01:29 PM
Hi helloPete,
From what I understand, the use of the inp and outp ( functions in CVI are not useable on 64 bit operating systems as is mentioned in this KB.
06-15-2016 07:27 AM
Thanks for the answer. I have given up the try on 64bit system, and reinstall my PC to Win7 32bit. So far the program works fine but waste my new 8G memory. 😞
06-16-2016 11:08 PM
Hi, Haywac, this issue was solved or not? I repeated the same problem you observed, I installed different release packages of Win7 32bit system, some release can work fine with the CVILowLevelSupportDriverLoaded command and return 1, someothers returned 0. I think there must be some different between the win7 32bit releases. or caused by different windows updates, who knows. really an aweful story on this command.
06-17-2016 01:58 AM
I don't know why you want to use the paralle port and what you intend to use it for, but if I were you I'd search for any alternative that doesn't rely on inp and outp.
As of my experience, 32-bit systems are becoming a rarity and several systems on the market don't even have a parallel port onboard. Additionally, I don't feel happy in having to unnecessarily run an application with administrative privileges. Considering that several cheap digital I/O boards exist, I wonder if purchasing one of them isn't better than spending time in installing/configuring/testing/modifying the systme without warranty it can be actually used and survive periodic OS updates.
06-17-2016 03:33 AM
Thanks for the answer. About 10 years before. I use this function to achieve about 1MHz pulse to realtime control a step motor. Recently, I tried three kinds of PCI boards, they all use command instead of realtime pulse control. Have to goback to this old function. Will try the other solutions.
