There are two possible reasons for this:
1. There is a new version of the driver for CVI 7.1, you will need that version of driver;
2. Whening installing the driver, the location of where the driver should saved is changed, you will need to make sure the driver is installed in the CVI7.1 folder, not the CVI6.0 folder.
Reinstalling the IVI Compliance package might help but I would check on the driver itself first. It also helps if you let us know which driver you were trying to install so I can try it as well.
