NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
chimbotano
Accepted Solution
I can't run my DLLs without having Intel Fortran Composer in the computer
I compiled some DLLs using Miscrosoft Visual Studio and Intel Fortran Composer. In my computer they run fine but when I try to run them on a different computer that doesn't have MVS and the Compiler I get this message:
Application Error
The application was unable to start correctly (0xc000007b). Click OK to close this application.
Is there a way to run these DLLs without having MVS and the compiler in the computer?
Felipe Lopez
Active Participant mvr
Active Participant
mvr
Re: I can't run my DLLs without having Intel Fortran Composer in the computer
At one time the runtime files required to be redistributed to support an application built with the intel fortran compiler were listed in the intel file "fredist.txt."  You would have to determine which files from the list you needed to repackage with your specific application.  Intel did not charge a license fee for redistibution with an application.
Member
blakney
The newest Intel libraries have a folder called "redist" for redistrubutable. For the IPP, the library is at "C:\\Program Files (x86)\Intel\ComposerXE-2011\redist). My take is that they did this to avoid confusion about what one was allowed to redistribute.
Good Luck
Member
chimbotano
I found the files I needed in C:\Program Files (x86)\Intel\ComposerXE-2011\redist\ia32\compiler. Thanks!
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
