LabWindows/CVI
CVI disregards breakpoints
CVI (both 8.5.1 and 2013 SP1) is not respecting my breakpoints if I open the project from a network folder.
It does not "break at first step" also.
I am sure it is in debug mode, and I tried a clean build.
I have all the access rights (read/write/delete/modify/create etc...) on that network folder.
The only solution is to copy the project to a local folder, then it starts to break properly.
I do not think this is expected behavior. Is it?!
S. Eren BALCI
IMESTEK
Message 1 of 10
(5,873 Views)
While compiling (running  debug mode) it will create a folder 'cvibuild.(project name)' in the project folder. You delete this folder and run again.
I have seen this is helping similar problems
Sajy
Message 2 of 10
(5,858 Views)
Hi Sajy,
Thanks for commenting on this.
I already tried that. That was what I meant by a "clean build" in my post.
Any other suggestions?
S. Eren BALCI
IMESTEK
Message 3 of 10
(5,851 Views)
I will appreciate if NI can comment if this is expected behavior.
We are 2 people (see francois_Campbell's thread also) who encountered this issue, and I cannot find a reason why debugging should be disabled when project is on a network folder.
Thanks.
S. Eren BALCI
IMESTEK
Message 4 of 10
(5,822 Views)
Hi ebalci,
I do not believe that this should be expected behavior.  I have a few questions for you:
1) What OS are you running CVI on?
2) What happens if you create a simple project from template, add a breakpoint, and then move the project to a network drive?
3) Aside from missing the breakpoint, does the rest of your application execute correctly when placed on the network drive?
Message 5 of 10
(5,795 Views)
Hi LindsW,
Thanks for paying attention.
- I was running WinXp SP3.
- I am on holiday for the week, I cannot try this before next Monday.
- Yes, it was executing correctly as far as I could observe. My attention was on the breakpoint issue, so I didn't go deep into application. I was trying to break at the beginning of the code and when it did not I closed the session to try something else. I thought I was missing some critical point.
S. Eren BALCI
IMESTEK
Message 6 of 10
(5,789 Views)
Hi ebalci,
Thanks for the update.  Just to make sure, I tried it out on my end with a very simple project, and CVI did stop at the breakpoints.  Perhaps when you get back from holiday you could give it a try on your machine, and we can work from there!
Message 7 of 10
(5,768 Views)
I also had this problem a few times. I 'solved' it by closing / reopening CVI. I hadn't noticed whether happened only on network drives, but I do have several projects like this.
Message 8 of 10
(5,753 Views)
Closing and reopening CVI solved the problem at my application!
Thanks for the hint
gerygery
Message 9 of 10
(3,187 Views)
Thank you! Did the trick for me as well. It is not only confined to network drives. Very frustrating.
In my case it was able to "break on... -> first statement" (using the menu), but the manual breakpoint I put on the very first line did not break.
Message 10 of 10
(2,213 Views)
