Hello, I have to use an application in LabView through CVI. Now when I launch the application (LabView), I am able to send only one command, while I need to send a several commands. How can I keep application in run time (LabView) for all time I need to send commands. With Best Regards
Hi, please, could you explain me your issue with more specifications? For example: your CVI and Labview versions, how you call the labview VI from CVI, what communication are you using to pass the commands... regards AlbertoA
2.Using LabWindows/CVI as an ActiveX Client to Run LabVIEW VIs. http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DB5F56A4E034080020E74861&p_node=DZ52156
