LabWindows/CVI
CVI 2013 SP1 crashes when opening file
LabWindows 2013 SP1 has suddenly stopped functioning on my PC.  Any time I try to open a file, either by clicking Browse on the welcome page, clicking the File Open icon, or selecting File - Open or File - Save As from the main menu, I get a popup Windows message that says "LabWindows/CVI 2013 has stopped working".
Clicking on "Show problem details" shows this:
Problem signature:
  Problem Event Name: BEX
  Application Name: cvi.exe
  Application Version: 13.0.1.201
  Application Timestamp: 52d6eeab
  Fault Module Name: CVI.dll
  Fault Module Version: 13.0.1.201
  Fault Module Timestamp: 52d6eea1
  Exception Offset: 00a4ecd0
  Exception Code: c0000409
  Exception Data: 00000000
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 1033
  Additional Information 1: 417a
  Additional Information 2: 417afcd3ce602885d582521ac0f0405e
  Additional Information 3: 39bb
  Additional Information 4: 39bb24ea28d79f3c45538f96792cdc59
These values are always the same.
I am running Windows 7 Professional, SP 1.
Message 1 of 9
(4,677 Views)
Were there any noticeable changes to your PC between the time CVI was functional and non-functional? Also, does this only happen when opening a particular project, or does this happen with any project?
If this problem is specific to CVI and not a particular project, you should try a Force Reinstall to overwrite any potentially corrupted files.
https://www.linkedin.com/in/trentweaver
Message 2 of 9
(4,615 Views)
It happens with any project.
I haven't installed any new programs on my PC, but our I.T. department periodically deploys patches onto our machines, so something could have changed that I'm not aware of.
Message 3 of 9
(4,609 Views)
I just installed CVI 2015 and I am still having the same problem.
Message 4 of 9
(4,595 Views)
Here is the crash information from CVI 2015:
Problem signature:
  Application Version:                           15.0.0.408
 Application Timestamp:                     5583c33f
  Fault Module Version:                        15.0.0.408
  Fault Module Timestamp:                  5583c332
  Exception Offset:                                00a6e310
  Locale ID:                                             1033
  Additional Information 3:                  1847
  Additional Information 4:                  1847e41850adf6e95315ac08efe0215c
Message 5 of 9
(4,591 Views)
Accepted by richferrara
If you just did a normal install of CVI 2015, it might still be worth trying a force reinstall. It's possible that there is a corrupted CVI 2013 file somewhere.
Taking information from a similar post here, it seems like this issue could be specific to your Windows configuration.
Message 6 of 9
(4,577 Views)
Would you mind posting what you see in <SysWOW64>\cvirte\, including all files and versions?
Daniel Dorroh
Message 7 of 9
(4,565 Views)
Here it is.
Message 8 of 9
(4,543 Views)
I uninstalled all LabWindows versions and all other National Instruments software from my PC, rebooted, and reinstalled the most recent version (2015) and the 8.1 SDK.  This appears to have fixed the problem.
Message 9 of 9
(4,299 Views)
