08-03-2006 09:57 AM
08-07-2006 06:18 PM
08-08-2006 08:55 AM
Hi Justin,
Thanks very much. I have given up on it and have been working on using listboxes and DirSelectPopup to make it work. The File browser is a much cleaner approach and a lot more user friendly. If you can figure it out, I and I'm sure others would be very grateful.
Thanks very much,
Dan
08-08-2006 11:23 AM
Dan,
I wrote an example of how to use the file browser. It was a little tricky because I had to dynamically figure out what the control id of the right hand side of the file browser was. After I figured this out, all I had to do was install a callback function for this panel and look at what the selected value was.
I hope this helps,
Justin D.
Applications Engineer
08-09-2006 08:52 AM
