visa read 8 bits to 32 bits ?
I run a counter  to measure the number  of  pulses  count  and i send that number  over  serial to bluetooth HC 06  to virtual serial port in my laptop . to do that i break unsigned 32 bit value count into 8 bit pieces a b c d  shift it 0, 8, 16 and 24 bit positions to the right to send it via  UART  .problem is how to  reassemble 8 bit pieces with labview on the other end.i have to shift a b c d 0, 8, 16 and 24 bit positions to the left and reassemble them with or .this is a c example :
unsigned char a,b,c,d;//final result dcba
a=0x09;b=0xEF;c=0xCD;d=0xAB;
intcount;
count=0x00000000;
count=count|a;
inttemp=b<<8;
count=count|temp;
temp=c<<16;
count=count|temp;
temp=d<<24;
count=count|temp;
(2,910 Views)
Accepted by aymanch
Hi aymanch,
this would be a straight-forward approach:
You receive 4 bytes and put them together using the Join function.
There are other (more advanced) approaches like TypeCast or UnflattenFromString…
(2,903 Views)
In LabVIEW just use decimate array and join numbers.
"Should be" isn't "Is" -Jay
(2,898 Views)
But how do you know the byte order that you receive? Any serial read is asynchronous with what you are transmitting. You would need s prefix for each byte or one for the entire packet.
(2,883 Views)
Unflatten From String makes this easy.
GCentral
(2,876 Views)
Oh, you can use an array if you have multiple samples...
GCentral
(2,871 Views)
thank  you guys for your guidance and support that's really help me . just another question , i have two serial to bluetooth devices both send count to pc.what i want to know is can i have the name or mac adress anything i can identify bluetooth device without seding data to it with visa if possible.second thing can i connect on with a device the close session and connect with second device on the same com is that possible.i want to use bluetooth as rfid to identify a wagon if u understand what i mean .anyway i am new here so ur help push me to continue and to learn more .thanks.
(2,820 Views)
