to more specific class error
Hi folks,
I have a parent and child class. The parent has a must override method and I'm trying to setup the parent class details then pass it to the child method. When I run it, at runtime, it actually runs the parent method. Afterwards. I see the block diagram has been modified to show a call to the parent method. I then try inserting a to more specific class function and it comes out with an error. All I can say is that none of my vi's are broken, and it's definitely shown as parent child in the hierarchy diagram/properties of class. Any ideas why this might fail?
Rik
(2,380 Views)
Can you post a code snippet or a VI attachment so we can see the VI in question as well as how you're calling it?
There might be any number of things that could cause what you describe but it's hard to know which one without seeing code.
(2,357 Views)
