speech recognition by labview and Arduino
I want to speech recognition with Labview and Arduino. I install already driver of Arduino and Test it in Labview. I want to ask If it is possible, guide me if I want use Hidden Markov and ANN algorithm, what should I do. Actually this project is belongs to control robot by voice but my knowledge about labview is not so much.
Your attention is highly appreciated in advance.
Best Regards,
Mohammad Pasvar
Message 1 of 16
(4,806 Views)
Hello Mohammad,
Regarding using Artificial Neural Networks in LabVIEW I would suggesst having a look over here:
https://decibel.ni.com/content/docs/DOC-17620
Are there certain problems/issues you're running into while using the NI LabVIEW Interface for Arduino Toolkit (http://sine.ni.com/nips/cds/view/p/lang/en/nid/209835) or while creating your Hidden Markov Model?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 16
(4,781 Views)
Hi
thanx for replying me, I checked that linke you gave it. I tried to understand but now I dont know how it works for voice recognition. Do you know any source, that explain the way of programming for robotic part, such as Algorithem, Obstacle avoidance.
Best Regards,
Mohammad Pasvar
Message 3 of 16
(4,773 Views)
Hello Mohammad,
Based on what are you planning to do Obstacle Avoidance (Vision, sonar,...) there are some examples that can be more and others that are less useful..
I did a quick search on ni.com and found the following examples:
https://decibel.ni.com/content/docs/DOC-13467
http://zone.ni.com/devzone/cda/epd/p/id/5966
http://zone.ni.com/reference/en-XX/help/372983B-01/lvrobovi/obstacle_avoid_pal/
Kind Regards,
Message 4 of 16
(4,753 Views)
Hi
I have a problem for build algorithm in Labview, I dont know how to build Hidden Markov Model as speech recognition algorithm.
Best Regards,
Mohammad Pasvar
Message 5 of 16
(4,726 Views)
Hello Mohammed,
Are you familiar with the theories behing Hidden Markov Models?
A good place to start would be for example this document:
http://sites.stat.psu.edu/~jiali/course/stat597e/notes2/hmm.pdf
Kind Regards,
Message 6 of 16
(4,709 Views)
Accepted by moha62
Hello Mohammed,
Kind Regards,
Message 7 of 16
(4,709 Views)
Dear Thierry C,
thanx again for repplying me. I want to ask you more if it is possible. Can you guide me, how can I do HMM in Labview now?
Best Regards,
Mohammad Pasvar
Message 8 of 16
(4,663 Views)
Hello Mohammad,
What you will have to do is actually the same as in another programming language.
First you'll have to define your algorithm that you want to use.
Once you've defined this, then you can start with implementing it in LabVIEW.
I did a quick search for existing algorithms and this one looks like something you might be able to use:
http://www.shokhirev.com/nikolai/abc/alg/hmm/hmm.html
Also please do a search and double check at your side to make sure that these algorithms are the ones you want to use.
Kind Regards,
Message 9 of 16
(4,639 Views)
Dear Thierry C
Sorry again me. Do you know any simple way to voice recognition to control robot without using any algorithim?
Message 10 of 16
(4,537 Views)
