I'm trying to synchronize 2 NI USB-6211 devices (dev1: Master, Dev2: slave).
The tricky part is that I need different sampling rates.
Now I tried to route the 20MHz timebase to PFI4 on Dev1. Ok, I get
something like a LVDS signal on the PFI4 pin. (2.3V mean, 1Vpp)
Then I wired (hardware) PFI4 of Dev1 to PFI0 on Dev2.
In LabVIEW I tried to use PFI0 (Dev2) as external timebase for
AI-aquisition (Timing-Property:SampleClock:timebase:clk). Without
success.
What am I doing wrong? I cound't find any hint in the docs about the
signal type on an external clock. Are external clocks supposed to be
TTL (0-5V)? If so, why is the "exported timebase"-signal on Dev1 LVDS?
Do I have to convert this LVDS-type signal to TTL before feeding it
back into Dev2 as external clock signal?
-DB
