regular exp
i have a string buffer like this  \s\sNN.NN\s\s\s\sNN.NN\s\n
where NN.NN is value is measurement is OK  , could be open is not present
I would like to extract this two NN.NN  with regexp
an idea ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 1 of 19
(4,517 Views)
You could use the scan from string function:
Message 2 of 19
(4,502 Views)
I know I should not assume that you would want the values to be converted to doubles.
Here's a link to the regular expressions thread, which may be useful:
http://forums.ni.com/t5/BreakPoint/Regular-Expressions-Board/td-p/1187799
Message 3 of 19
(4,497 Views)
I have to run to a meeting, but here is a quick reg expression.  You'll need to fix it to get 2 significant digits:
Message 4 of 19
(4,491 Views)
This VERY SLIGHT modification gets you all the digits past the decimal point.  You can replace the asterisk with {n} to specify exactly how many digits you want.
Jim
Message 5 of 19
(4,475 Views)
With one MRE (assumes only spaces separate the numbers):
Jim
Message 6 of 19
(4,470 Views)
You can simplify the regex to "\S+", one or more character that is not a space if the output is always of the type \s\sNN.NN\s\s\s\sNN.NN\s\n.
Ben64
Message 7 of 19
(4,464 Views)
Alternate regex
Ben64
Message 8 of 19
(4,460 Views)
In terms of flexibility and syntax error catching, I tend to prefer to use the digit class (\d).  Let me just remind the regexers about negative numbers.  Smiley Wink
If spaces are the enemy, then Ray.R chose the correct function but wandered into RG territory when he thought strings would be the desired output.  Just let Scan From String do its voodoo.
Message 9 of 19
(4,446 Views)
We still don't know if the OP wants doubles or strings or why use regular expression at all.  I decided to go the regEx example because that was what was asked..
Thanks Jim for the simplified examples.  I enjoy learning more regEx.
I prefer the Scan from String as it does the trick..  and it can convert to the appropriate type in one shot.  🙂
Message 10 of 19
(4,427 Views)
