read a frame from a mpeg video
I need to progammatically read a frame from a mpeg video.
I have already tried to make use of ffmpeg and convert the video in a PNGs (or whatever) sequence but now I would develop a more performing solution.
Did anyone try or need something similar?
Thanks!
(6,311 Views)
Hi simroc76,
the mpeg video format is not native supported by LabVIEW.
If you want to read a mpeg video, one possible solution is to convert the mpeg file to an .avi file. If you want to create solution with a higher performance, i can give you two possible solutions:
1) Maybe the ffmpeg application provides a dll, which you can call from LabVIEW. With this approach, you would use the CIN-Node from LabVIEW to control the function of ffmpe. I don't know, if ffmpeg provides such a function. If not, you must search in the internet for a application, which offers you this function. If you never used a DLL with the CIN-Node, this links are really helpful:
Writing Win32 Dynamic Link Libraries (DLLs) and Calling Them from LabVIEW - Developer Zone - National Instruments
http://www.ni.com/white-paper/4877/en
Integrating External Code with the Import Shared Library Wizard
https://www.ni.com/docs/en-US/bundle/labview/page/using-the-import-shared-library-wizard.html
2) Another approach is to use ActiveX to get an frame. With ActiveX, you can control another application and can excange Data between LabVIEW and another application. This solution would also not be very easy, but it is an opption to import a frame from an avi-file into LabVIEW. If you want to know what is possible with ActiveX, you can use this example:
Community: Creating a Hyperlink to a cell in Excel via Active X
https://forums.ni.com/t5/Archive-TKB/Creating-a-Hyperlink-to-a-cell-in-Excel-via-Active-X/ta-p/34948...
(6,279 Views)
Accepted by topic author simroc76
Thanks for the reply Stephan.
I solved my issue!
After several tests, I've used an OpenCV dll: opencv_highgui240.dll (version 2.4.0).
Since I had some issues with dll included into the official OpenCV package, I've used the ones included into the Emgu package http://www.emgu.com/wiki/index.php/Main_Page
That dll is not static, so I had to take care about the Windows current working directory (see here https://forums.ni.com/t5/Example-Code/Get-Set-Windows-Current-Working-Directory-in-LabVIEW/ta-p/3507... ).
Now I am able to extract  frames from a MPEG2 video and put them into an IMAQ RGB image (with 640x480 frames I need 10 msec for each frame).
(6,270 Views)
Hi simroc76,
thanks for your replay. Great that you could solve the issue with a DLL which converts the mpeg frames on the fly into LabVIEW.
Would it be possible for you to post your solution? I think that your solution would be helpfull for other forum user, which deal with the same problem an also search for a way to get mpeg frames into LabVIEW.
Stephan
(6,244 Views)
If you dont mind sharing your example, i would love to see it as well.
Thanks!
(6,215 Views)
If you can share your solution i was appreciate you. Thanks
(5,948 Views)
