Overview
This example shows how to get or set Windows current working directory by calling Windows dll.
Description
Sometimes when working with LabVIEW you may need to get or set the Windows current working directory, especially when interacting with another application using either files or Active X.
This is a simple VI that can get or set the current working directory. If a directory path is entered, the example will set the current working directory. If no input is entered, the VI will return the current working directory path.
There is no direct function in LabVIEW allowing to achieve this goal, so this example VI calls a Windows DLL to provide the functionality.
Requirements
