"VISA: (Hex 0xBFFF0015) Timeout expired before operation completed."
Hello.
I buy new machine, which is "SPECTROMETER BIM-6001" made by brolight. Of cause, I receive the USB driver, but it's not working in Labview if I use it.
I solved this problem to use this document. -> http://www.ni.com/tutorial/4478/en/#
And I open the NI MAX, VISA test Panel. Of cause, Device is connected.
Now, it is problem.
First, I can't change the "Control Pipe" from Default (0).
Second, I enter basic I/O in Input/Output. I type command " *IND?\n ", push "Query" button. and I get return Data as following this.
------Return Data---------------
Read Operation
Error
"bytes to Read" is 1024.
I guess its problem is associated configuration.
I checked View Attributes, in Configuration panel, found strange thing.
Attribute                            |       Currnet Value
Bulk Out Pipe                   |       0x3
Bulk In Pipe                      |       0x81
Interrupt In Pipe                |       -1 (No Interrupt In Pipes Present
Interrupt In Pipe State       |      UNKNOWN
OS is windows 10.
Happy new year,  greeting
Mattew
(2,859 Views)
I have not looked at the manual yet, but I would guess the instrument does not take the SCPI commands.  It likely has a proprietary protocol.  If there is a driver, you will likely have to interface through that.
GCentral
(2,810 Views)
Thanks for your response.
I agree to your opinion and I have USB driver for my machine.
Do you know how to interface using my USB driver?
Is it some document in this web site?
(2,802 Views)
Assuming you have a DLL, you will need to use the Call Library Function Node.  Dig around the user manual to see if there are example using the driver.
GCentral
(2,797 Views)
