07-31-2010 10:03 PM
Just go through the attachement
I made some corrections and removed the broken wires and added one more configuration palette.
Please check whether it is correct or not?
07-31-2010 10:42 PM
It's correct if you want to shut the supply off if there is no overcurrent condition. Your logic is wrong and I don't understand why you are comparing the voltage out to the current setting. Since the voltage will drop and the current will go to the max, shouldn't you compare the voltage out to the voltage you set it to?
07-31-2010 10:45 PM
Oh no sorry sorry
it is mistakenly drawn, it is to be connected to the output current
07-31-2010 11:01 PM
That is not correct either.
Have you read the answers given? With a fault, your output voltage will be less than what you set it to. Your output current will not exceed the max you set it to.
07-31-2010 11:29 PM
OK OK
I mean the configuration is correct or not? voltage also we can set like that I agree.
More over I am preferring through the current limit only. but if it is not possible then voltage only the solution
Problem solved.
08-01-2010 03:12 AM
08-01-2010 10:12 AM
Problem solved.
The problem not solved. Because two output switches which is having different states is not possible to work in the same loop
I'm sorry, but I don't understand what you are saying here. I have no idea what you mean by preferring the current limit only, and "voltage only the solution", or "two output switches which is having different states". Please explain more clearly or provide an updated diagram.
08-01-2010 01:51 PM
please refer the first image i uploaded. in there two configuration palette are used in this palette also having the output ON/OFF switch /boolean. In a loop two boolean for same purpose. mean power supply ON/OFF. first one is for ON the supply and the second one is for OFF after comparing the measure current/voltage with set current/voltage. Means if the measured is going beyond the set limit it will switch OFF the power supply. But the first one will be in ON state only. even after sensing/comparing high current or low voltage. In the same loop two same type boolean having one is true and the other is false.It will ON and OFF the power supply simultaneously.
08-01-2010 02:01 PM
Both are different thread only
one power supply (Agilent) having +/- output and the
other one is, two separate power supply(Lambda 36-6) to make +/- output
but in Lambda foldback function is there we can use this function.
the output is configured as +/-power supply so this should switch ON/OFF at a time/at same time
08-02-2010 07:01 AM
