06-09-2016 01:47 AM
I am making test temperature for a motor using a pico logger TC-08. I am actually via this program saving the values of temperature every 1 minute in the current time.
After waiting 20minutes, I am supposed to start a boucle where i compare the value of temperature tooken at 20min with those tooken at 0.
To be simple I have everytime to compare, T20, T0/ T21,T1/T22,T2/T23.T3... with always a delta T equal to 20min.
I didnt find a way to get out the values already tooken... I'll join my VI
All help or suggestion is most than welcome
06-13-2016 04:21 AM
1) https://decibel.ni.com/content/docs/DOC-4785, here you will find an example that could help you.
2) http://www.ni.com/newsletter/51735/en/, here you will find some "best practices" to respect modularity, LabVIEW dataflow, Design Pattern and so forth
Dasso
