06-10-2016 02:17 AM
Hello
I'd like to do a linear regression of -20 dB and -30 dB on a graph, could someone tell me how I should go about it?
Thank you
06-10-2016 02:25 AM
You can try out with Linear Fit.vi or Logarithm Fit.vi
BR,
Vincent
06-10-2016 03:39 AM
06-10-2016 03:53 AM
06-10-2016 04:09 AM
Simply create this point!
The point can vary so how can I do?
Questions as usual:
- What is the problem exactly?
I have a graph with a fall in dB versus time, to be precise in our calculations, I am asked to study the curve with a drop of -5 dB maximum point (initially we have a tray so to -5dB from the tray) and then I have to do a linear regression of all the points for a fall to -20 dB and the exact same thing to -30 dB.
- Spirit of attaching an example VI?
My vi is not yet finished, infact I can not even see my graph because I'm not in good conditions.
- How do you want to interpolate? (Linear? Logarithmic?)
What is interesting to me is the linearity points
06-10-2016 05:37 AM
Hi G.,
It REALLY would help when you would attach an image of what you're talking about!
What are "linearity points"?
LabVIEW comes with functions for linear regression…
06-10-2016 06:22 AM
I let as an attachment that I must have.
I have to study the curve at -5 dB of the maximum, so here we consider the curve from only 75 dB, then make a linear regression of 75 dB to 55 dB (-20 dB drop), but also 75 dB to 45 dB (-30 dB drop).
I use linear regression function but I do not see how I can not tell him each time to each point.
thank you very much for your help
06-10-2016 07:52 AM
06-10-2016 08:11 AM
06-10-2016 08:26 AM
Do a linear regression on a subset of the array. Pick the part of the array that is within the limits you want.
