myrio loses connection on excution of a complicated formula node
I haven't used a myRIO but I'm pretty sure the compiler would optimize the code better if the formula was done in native G code instead.  Maybe this would free up some resources, allow constant folding, or allow parallel operations where the text code forces serial operations.  If you do this I recommend making subVIs for common functions, and inlineing the VIs to allow parallel operations.
Message 11 of 12
(340 Views)
My thoughts exactly. When a formula node starts executing does it allow time slices for other things to execute?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(332 Views)
