05-05-2012 03:24 AM
Hi everybody
I have a NI-6008 Low cost multifunction DAQ.
Can i use this with voltage level shifter to implement I2C protocol...
05-05-2012 09:14 AM
You'd need to use the bit-banging approach (i.e., you change the clock and data lines yourself) and it would be software-timed. But yeah, you could do it.
Your next question will be: are there any examples? There are plenty of examples on doing digital I/O that get installed with DAQmx. As for I2C implementation, the spec is available. http://en.wikipedia.org/wiki/I%C2%B2C
05-21-2012 11:18 PM
Sorry but after much testing and different bit-banging approch we came to conclusion that NI-6008 is much slower device to handle I2C so we are switching to NI-845x but lots of thanks to everybody for their help....
07-03-2014 05:07 AM
Is there any NI modules which contains analog measurements and digital measurements and frequency and also main I2C communication in one module???
Please give a suggesion if any third party modules also including above parameters.
07-03-2014 06:07 AM
07-03-2014 07:24 AM
Have you thought of using an Arduino? I haven't tried it myself yet but it has I2C capabilities built in. There is a large LV community supporting it.
