11-18-2009 02:19 AM
I have three columns of data, X (lattitude), Y (longitude) Z temperature,
how can I plot a graph as shown in the picture.
I tried the intensity graph, yet could not get the desired result, any hint is greatly appreciated.
11-18-2009 07:07 AM
11-18-2009 07:44 AM
The intensity graph is not exactly like your example, The intensity graph takes an XYZ maxtrx (array ox X and Y size with values of Z) you might beable to fake it out by setting all points along the long-lat path to their interpolated values and all else to zero.
You really want an XY graph with a color intensity key. Since plots can not be different colors, this complicates things.
Options
1. use a multiXY plot making line segments to be different plots and the colors of the plots to match youe intensity scale.
2. Use a 3d plot and view it from a birds eye view (making it 2-d) . Probably easiest
3. Make the plot in a picture control
I would try using the 3d line plot where there is the possibility of scaling the Z axis by color (I seem to recall an option to do this.
11-18-2009 08:18 PM
I need to overlay a map under the graph, I was wondering if I can still use the 3D plot and the bird view, it seems that I could not make the 3D plot background transparent.
could you give more details for the picture container option? thanks a lot
11-19-2009 01:31 PM
