flow control or any ideas using labview
Msc engineering assignment ...i have to design and build a hardware for industrial control application..?
the industry can be aerospace, automotive, manufacturing,medical, domestic..etc
I need an idea pls help..
Message 1 of 10
(5,546 Views)
Maybe get an engineering degree? Sorry if it sounds like a harsh reply but the question is extremely vague.
LabVIEW 2012
Message 2 of 10
(5,542 Views)
How about a computer controlled hydroponic hothouse tomato factory?
EDIT:  I thought it was silly too Steve, but at least I tried! Smiley Tongue
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 3 of 10
(5,537 Views)
So you are looking for ideas on what to design and not how to design it? That makes a big difference. If it is the latter then it is actually a good question.
A fun and easy project is a temperature control loop. You can use a 35mm film canister (can you still get those?) with a lightbulb and a thermocouple inside of it. Using a PWM signal to the lightbulb controlled by LabVIEW you can set the temperature inside of the canister.
Is that what you are asking? Sorry if I misunderstood your post.
LabVIEW 2012
Message 4 of 10
(5,529 Views)
I say we go after a time machine. I bet we could get a DeLoran real cheap and it would not take long to whip up a flux capacitor.
Tim
GHSP
Message 5 of 10
(5,517 Views)
I got the flux capacitor but I'm afraid I don't know where to get a DeLorean.
LabVIEW 2012
Message 6 of 10
(5,502 Views)
DeLoreans were made in Northern Ireland in the 70s.  Once we have a time machine we can go back and get one.
Message 7 of 10
(5,489 Views)
Ethernet Sniffer.
No hardware required beyond the PC. It will give you a chance to explore acquiring data from the network and formatting it for display. Optionally save the data to file for latter review. It may even give you a chance to spy on the person in the next dorm room and no flux capacitors or time machines required.
Ben
Message 8 of 10
(5,482 Views)
And the LabVIEW question here is?  Smiley Tongue
A whack-a-mole machine. A learning experience, and fun, too!
alfa beat you to it
Message 9 of 10
(5,477 Views)
Deloreans are available now, flux capacitors ...
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 10 of 10
(5,476 Views)
