elements from two FOR loop
Hello
I am having 2 FOR Loops. Both loops run for a particular number of times. Inside the inner loop, i am getiing a 2D array of 4  complex numbers each time when the loop runs. I need to get every element from this for the whole number of times the FOR loop is running. How is this possible? See attachment.
Nghtcwrlr
Message 1 of 16
(2,967 Views)
Right click on the tunnel and select "Disable Indexing".
Post if this is what you want.
Mathan
Message 2 of 16
(2,963 Views)
Hello Mathan
I tried to "Disable Indexing" in both the loops and tried to get the output. But still am getting only the final 4 values. When running the VI i can see all the elements  but th efinal result is only the last 4 values.
Nghtcwrlr
Message 3 of 16
(2,956 Views)
See Attached VI...
Nghtcwrlr
Message 4 of 16
(2,937 Views)
Hm, i am unable to read what the vi should accomplish......maybe you can describe the purpose of that algorithm?
Norbert
Norbert
Expert: Geometry
Message 5 of 16
(2,927 Views)
Hello Norbert
From the 2D array it takes values based on  x+y array indices. For each time the loop runs, 4 values from the 2D array is taken . I need to get all these values as one single 2D array.
Nghtcwrlr
Message 6 of 16
(2,915 Views)
Still, i am not certain if i understand your request. But i think that you should look into using shift registers.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 7 of 16
(2,894 Views)
Hello  Norbert
I have also tried with shift registers. but didnt work. The actual situation is like this:
1) am having a set of calculations that gives 4 elements in a 2 D array based on some values. This is inside TWO for loop. Each time the loop is performed, 4 values are given out as output and this out put is interpolated to get a single value. What i need is to get all these set of 4 elements as a single 2D array.
Nghtcwrlr
Message 8 of 16
(2,887 Views)
The problem is that your array handling is incorrect. You always extract a part from your original array and place it in the outputtunnel. Next iteration, the previous part is gone.... So either you place your interpolation into the array as well, or you can introduce a third dimension to "stack" those 2x2-arrays.
Like i said, i don't understand what you are up to in your VI, so i don't know if my suggestions fit to your task.
If you decide to explain what your application should do, step a little back and describe it without using any expression like "for loop"....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 9 of 16
(2,883 Views)
Hello Nobert
Yes.. that is the problem.I always extract a part from your original array and place it in the outputtunnel. Next iteration, the previous part is gone.... So what do you mean by  introducng a third dimension to "stack" those 2x2-arrays???
Nghtcwrlr
Message 10 of 16
(2,865 Views)
