elements from two FOR loop
Hi Nghtcrwlr,
activate autoindexing of your loop outputs. You will get an 3,4,... dimension array. If you want only a 2x2 array you can then use the Reshape Array function.
Hope it helps.
Mike
Message 11 of 16
(1,199 Views)
Hello Mike
As mentioned by Nobert, the 4 values are taken once and then another 4 values comes in the next iteration. so only final 4 values are obtained even if we auto index the for loops.
Nghtcwrlr
Message 12 of 16
(1,194 Views)
You really have a fundamental misunderstanding here. Your code in the false statement creates a new array every time the case is called. You have to use a shift register and keep operating on a single array. The false case would just past the shift register through. Have you looked at any of the shipping examples? There's a basic one called Separate Array Values that demonstrates a shift register.
Message 13 of 16
(1,193 Views)
Hello Dennis
But using a sgift register just gives nothing in the array. How come that possible? WHen i run the VI i can see all the values (4 values each time) its not stored anywhere.After each loop iteration new values are obtained. How is it possibel to store all values ?
Nghtcwrlr
Message 14 of 16
(1,168 Views)
If you get nothing in the array with a shift register, you are doing it incorrectly. In the true case, you use the Build Array to add a new element. In the false case, you wire the shift register straigh through. Look again at the shipping example I mentioned and if you still have problems, post your modified VI.
Message 15 of 16
(1,163 Views)
Hello dennis
Actually what i wanted was to get back the values used for interpolation. I mean .. i am havin a 2D array of values and I interpolate some of these values to get , say 8 new values. Now from this 8 new values i take 3 and need to find back the original values in the 2D array.
SO i think the way i was doin was wrong. DO you have any idea how to get back those original values?
Nghtcwrlr
Message 16 of 16
(1,126 Views)
